Page 1 of 2
ancillotti exhaust
Posted: Tue Nov 03, 2015 9:12 pm
by garry inglis
hi all there seems to be three types off ancillotti ie// scootopi Cambridge and gori and all different prices so which is the best thanks
Re: ancillotti exhaust
Posted: Tue Nov 03, 2015 10:04 pm
by rosscla
There's at least half a dozen more types than that ...
MB/BGM
AF
Casa
KBA
Indian big bore
Ancillotti
All loosely referred to as 'clubman' exhausts. This usually means a standard looking box pipe with a cone and a bigger diameter U bend. Some are better build quality, some more performance orientated, some noisier than others.
Best for what? You need to pick your exhaust to suit your starte of tune and where you want it to perform. Little use putting one of these on a motor that produces its power at high revs.
Posted: Tue Nov 03, 2015 10:05 pm
by gerryjunior
Gori as well,
Posted: Wed Nov 04, 2015 10:42 am
by garry inglis
fitting a mugello 186 to my Spanish li150 with 25mm dellorto and standard airbox with fast flow filter gp crank
Posted: Wed Nov 04, 2015 11:38 am
by immylam
mugellos can be problematic , Go for the MB/BGM with the correct swan neck for mugellos, (Scooter centre /sip Sell them) not sure if this is for all newer mugellokits but certainly caused me no end of problems with mine an Indian clubman and an ancilloti snapped at the casing bracket.
Posted: Wed Nov 04, 2015 1:29 pm
by ktmh5
immylam wrote:mugellos can be problematic , Go for the MB/BGM with the correct swan neck for mugellos, (Scooter centre /sip Sell them) not sure if this is for all newer mugellokits but certainly caused me no end of problems with mine an Indian clubman and an ancilloti snapped at the casing bracket.
Pretty sure that will be down to the exhaust themselves rather than the Mugello Kit. Most need fettling to some extent and if they are fitted stressed at any point they will break, usually at one of the brackets.
Posted: Wed Nov 04, 2015 2:34 pm
by garry inglis
Thanks MB is£185 but u no it's going to work through the rev range
Posted: Wed Nov 04, 2015 7:15 pm
by rosscla
ktmh5 wrote:immylam wrote:mugellos can be problematic , Go for the MB/BGM with the correct swan neck for mugellos, (Scooter centre /sip Sell them) not sure if this is for all newer mugellokits but certainly caused me no end of problems with mine an Indian clubman and an ancilloti snapped at the casing bracket.
Some muggellos have a different exhaust port depth so it's further from the axis of the cylinder. This can lead to some alignment issues.
Posted: Fri Nov 06, 2015 6:37 pm
by garry inglis
been on mbs site and he does a special swan neck for the newer mugello version as it is different to the first ones
Posted: Wed Nov 18, 2015 11:40 am
by soosh
Be good at some point to do a comparison test,lots on the market now.Some will say the Gori is the best,some say BGM and others swear by the Ancilotti.
