ts1 225 -gearing
Posted: Sun Jun 21, 2009 12:50 pm
by db67
hi, currentley running a straight out the box ts1 225 with a jl 3 pipe,gearing at the mo is li 150 with 17x48 sprockets (4:80) just wondered if this is about right or do i need to alter my crownwheel/sprocket slightly ?i mainly ride one up, thanks for any info. db
Re: ts1 225 -gearing
Posted: Mon Jun 22, 2009 9:16 am
by Ian M
Depends what you want it to do really, I'm not expert in this field others on here are more qualified than me but I run a 17x46 set up but with a Taffy pipe ok my barrell as had a little felting around the edges but this set up works well for me top end is around 85ish as it has load of grunt bottom end but it's not a rev monster in top ....needs to be set up like this as I'm a fat git ! you have to ask yourself you want a balls out racer or a torqey touring motor with a little less top end?
Big Ian
