Gearbox end plate
Posted: Wed Oct 21, 2015 9:00 pm
Just opened up a 68 Spanish LI g/box & the end plate studs are all needing heli-coiled(someone in the past has re-built the engine leaving a bit of a mess).
Trouble is with the end plate not being tightened properly it's been' rocking' leaving the dowel holes elongated. Anybody got any suggestions on a fix for this. My thought was getting a stepped dowel made, drilling out the engine case to match the larger diameter on the dowel with the smaller diameter matching the end plate.
Thanks in advance........
