Thoughts on this Monza 225 seize
Posted: Wed Oct 21, 2015 10:21 am
This current issue is a continuation of the topic below. I've probably found my own answer, which I will come to below. So the point of this thread is to confirm my thoughts and let other learn from my mistake.
http://scooterotica.org/forum/viewtopic ... 32&t=34355
Story since rebuild from above thread.
Top end re-built with Langcourts re Nikasil barrel and honed to match the new super Monza oiston that I sent.
Piston to bore clearance was 0.003 thou. No base or head gasket and squish at 1.1mm. 3% synthetic oil and number 8 plug
Jetted rich and then dynod at 150 miles. And when I say dynod, we had quite a few runs, with only subtle changes to get a reliable air to fuel ration right across the range. I
Then on the way home from dyno, on a cold night, with a clear road I thrashed it for 30 minutes, but as I rolled off the throttle coming into Skipton, I lost power instantly, so pulled in clutch and rolled to a stop. Kicked over and no compression, so once again, rang a friend with a van. I know that rolling off then throttle from a long distance run can cause this problem,, but from the dyno curves, the mixture at this rev range, was well within safe limits.
First thing when I got back home was to check the plug. As you can see below, its a great color, which confirms the jetting was OK. Last weekend, I stripped the top end, but before going too far, did an air leak test using the Grandpa and Coaster inner tube test and confirmed no leaks.
As you can see from the photos below, it was a type of heat seize to either side of the conrod and opposite the transfer ports. The rings were locked in at these two pints. Fortunately, the lining is still intact in the barrel and the smear on the piston is just that and has cleaned up well enough to re-use. Will re-build this weekend with new rings and new small end bearing, but am concerned that it may happen again.
However, when doing the initial top end re-build, I forgot to check the ring gap. Just done that this morning, with the old rings and getting around 0.15mm, which is way too small. So my thoughts are, ring gap too small, is the main reason.
Any thoughts would be gratefully appreciated?
Plug Colour
Barrel, bad photo, but no scoring in real life
Smears on piston and locked in rings
Plug Colour
