Page 1 of 2
Would this be worth doing?
Posted: Sun Oct 11, 2015 9:08 pm
by Nerdy Norm
I'll shortly be taking delivery of a Series 2 LI 125, which I believe is completely standard. Eventually I plan on making a few upgrades along the same lines as I've done on my Series 3 (BGM RT195, big bore exhaust, bigger carb, etc.).
Until funds allow, I'm thinking of fitting some bits I've got in my "take-off box", which from memory are a standard Series 3 LI 150 top end, a cheapo AF Clubman and a 22mm Jetex carb.
My first question is would these parts from a Series 3 fit a Series 2 without modification, and the second is would I gain any meaningful performance improvement, or should I just leave it as-is until I can run to some "proper" upgrades?
Thanks in advance!
Re: Would this be worth doing?
Posted: Sun Oct 11, 2015 9:32 pm
by coaster
I'd say it is definitely worth doing, it still won't be 'quick' but it'll be significantly better than a 125 and yes those parts will fit.
Posted: Mon Oct 12, 2015 6:45 am
by Nerdy Norm
Thanks Coaster - I'm not expecting miracles, but I was just thinking that those parts must make some kind of difference, so it's better that they're on the scooter than sitting in a box in the garage.
Posted: Mon Oct 12, 2015 9:16 am
by shocky
I think that would be a nice upgrade for relaxed use it might be undergeared but it depends were you going to use ot most groups are often slower as is around the city , just check you have a 150 slide in your carb you might find the 200 slide boggy mid range and be tempted to under jet the main
Posted: Mon Oct 12, 2015 9:22 am
by Nerdy Norm
Thanks Shocky. The rides I'm likely to go on with this scooter certainly won't involve any motorway use, so I should be OK.
The Jetex came from Rimini, and was supplied as set up for a Casa 185 kit, so not sure what's inside it. Is there an easy way of identifying it?
Posted: Mon Oct 12, 2015 4:33 pm
by Nerdy Norm
To answer my own question, I've just opened the Jetex - it has the slide without a cut-out, which I believe is the 200 version. Do I need to replace that with the cut-out version for the 150?
The jets currently fitted are 140 main, with the other two being marked 50. Could someone give me a ballpark set of jet sizes to start with on a standard 150 top end with an AF Clubman?
Sorry for all the questions, just trying to be as frugal as possible with these upgrades!
Posted: Mon Oct 12, 2015 6:59 pm
by Chris in Margate
Somewhere around 110 main and then up or down from there.
Posted: Mon Oct 12, 2015 8:01 pm
by Nerdy Norm
Thanks Chris, I'll get some jets ordered.
Anyone know about the carb slide (with or without cut-out)?
Posted: Mon Oct 12, 2015 9:10 pm
by shocky
It is the cut out type but you can try the 200 one personally id jet it as per gp150 and go down on the main if needed , but jetting for one scooter to another can vary
Posted: Tue Oct 13, 2015 11:41 am
by Nerdy Norm
Thanks Shocky.
According to Beedspeed's chart, the GP150 used a 118 main jet. With a Clubman exhaust, isn't it normal to have to increase the main jet size a couple of points or so? In which case, 120 is quite a lot higher than the 110 Chris mentioned as a starting point.
On the same chart, it shows the pilot jet as being a 45. Since the one already fitted in my carb is a 50, I should also change that, right?
Beedspeed chart:
http://beedspeed.com/html-pages/Lambret ... etting.htm
