Ts1 gearing
Posted: Fri Oct 09, 2015 5:41 am
by db67
Hi, currently running Indian gp 200 gearing with 46x19 sprockets giving a 4.84 4th gear ratio, coupled with this is a 30mm dellorto carb & a bgm clubman ,this set-up runs great uphill ,against headwinds etc but im thinking of trying 47x20 to give me a 4.70 4th gear ratio . my question is I'm i best leaving as is or are other people running this set-up successfully with no drop's in performance? many thanks for any info ;) db67
Re: Ts1 gearing
Posted: Fri Oct 09, 2015 7:37 am
by Fux
Thats basicly the same ratio as me, also om a BGM clubman. You may be chasing gears if you up the ratio.
Re: Ts1 gearing
Posted: Fri Oct 09, 2015 9:11 am
by dansacred
my ts1 and mb clubman pull 4.7 just fine on an Li box
