Kits for a frame breather
Posted: Tue Oct 06, 2015 10:19 pm
by Livi- Graeme
Anyone fitted a 175 or 185 kit into a frame breather using the origional carb and filter system
Re: Kits for a frame breather
Posted: Wed Oct 07, 2015 5:14 pm
by dave wheeler
yup ,had an untuned SR175 barrel, ma19bs7 carb, was fine with standard pipe but when i put a casa s2 clubman it couldnt cope, suprisingly it was the float bowl that couldnt deliver enough fuel for the revs the clubman was working at, rather than the framebreather restricting airflow so i gave up, put a PHBL25 with a remote foam filter, wow! what a transformation, would be interested to hear if anyones had any luck with this carb using the original set up but the gains were so great i wont be going back to a standard carb
Posted: Wed Oct 07, 2015 8:43 pm
by Livi- Graeme
Was going to mabey stick an af 175 kit on it but might just opt for a 150 top end
Posted: Wed Oct 07, 2015 9:07 pm
by lambrusco
175 top end 20mm carb running with a 42 af clubman.
Posted: Wed Oct 07, 2015 9:19 pm
by Livi- Graeme
That's what I'm looking for. Thanks
Posted: Fri Oct 09, 2015 8:45 pm
by Livi- Graeme
Did you use both filters for this. Thanks graeme
Posted: Sat Oct 17, 2015 7:29 am
by lambrusco
Just the one you see at the front, nothing at the back.
Posted: Sat Oct 17, 2015 7:54 am
by Livi- Graeme
Thanks hector.
