Page 1 of 3
Not so merry christmas
Posted: Mon Oct 05, 2015 6:36 pm
by Snails
I dont think my xmas tree should be rubbing on the casing like this should it
I have the shim fitted. Would having the clutch in pull the tree up or do I need another shim?
Re: Not so merry christmas
Posted: Mon Oct 05, 2015 6:49 pm
by rosscla
Is the shim in under the outer bearing race in the casing? Don't see it in the picture?
Might be the roller race is hiding it -
But the track looks a long way in.
Posted: Mon Oct 05, 2015 7:06 pm
by Daggs
Your picture of the layshaft main bearing shows the plastic seals in. Which I don't recommend...........
Posted: Mon Oct 05, 2015 7:24 pm
by rosscla
I think that's just the grease you're seeing, no seal?
Posted: Mon Oct 05, 2015 7:37 pm
by Daggs
Gawd! That's a fair bit of grease..................
Posted: Mon Oct 05, 2015 8:17 pm
by hendy
My money says it's a seal.
Better tek it oot.
Posted: Mon Oct 05, 2015 8:18 pm
by hendy
Better tek it oot.
Posted: Mon Oct 05, 2015 8:27 pm
by HxPaul
Snails wrote:I dont think my xmas tree should be rubbing on the casing like this should it
Is it an aftermarket Indian Li 150 gearbox? If so I had one and it knackered the christmas tree bearing track.Running it without the shim was the only solution.
Posted: Mon Oct 05, 2015 9:39 pm
by rosscla
hendy wrote:My money says it's a seal.
Better tek it oot.
MB bearing no seal
Posted: Mon Oct 05, 2015 9:49 pm
by lambro
rosscla wrote:I think that's just the grease you're seeing, no seal?
If you have packed that much grease in the bearing to look like a seal,
Will the clutch plates like that?
Just curious.
