Page 1 of 2
Christmas tree bearing track
Posted: Sat Sep 26, 2015 4:53 pm
by boxofbits
The case harding has gone on the Christmas tree knackering the bearing and the track seems to have had a bit of wear is there a tool to get this thing out?
Re: Christmas tree bearing track
Posted: Sat Sep 26, 2015 5:34 pm
by wack 63
Find a steel bar that is a snug fit in the track, heat up casing and fill the track with grease then fit the bar and hit it with a hammer. Hydraulic pressure usually forces it out. Sticky's book shows how. Cluster can be repaired with a sleeve.
Posted: Sun Sep 27, 2015 4:59 am
by Grumpy225
Blind bearing puller and a little heat. Comes right out.
Posted: Sun Sep 27, 2015 7:50 pm
by Muppet
wack 63 wrote:Find a steel bar that is a snug fit in the track, heat up casing and fill the track with grease then fit the bar and hit it with a hammer. Hydraulic pressure usually forces it out. Sticky's book shows how. Cluster can be repaired with a sleeve.
+1
Posted: Mon Sep 28, 2015 8:30 am
by shocky
I found the repair to be more expensive than the cost of a second hand cluster
Posted: Mon Sep 28, 2015 8:55 am
by rosscla
Replacement track is about a tenner and the machining cost me 15£
Posted: Mon Sep 28, 2015 12:30 pm
by boxofbits
Is there a lip or gap behind the bearing race to get a blind bearing tool in ?
Posted: Mon Sep 28, 2015 5:54 pm
by Grumpy225
boxofbits wrote:Is there a lip or gap behind the bearing race to get a blind bearing tool in ?
Yes and there is a washer behind the race. Don't loose it.
If I have time this week I'll try to youtube a video of it.
Posted: Mon Sep 28, 2015 8:04 pm
by jason frost
Or weld a nut in to it and use a bolt to pull it put
Posted: Fri Oct 02, 2015 7:30 pm
by boxofbits
Got it with a puller easy I didn't pay a tension to how far the old one was in does it need to be flush got the new race in but it sticks out about 1.5 mm
