T 5 switch Help
mick1
Main scooter: Li Avanti 225
Fixing a MK1 T 5 and the wires have pulled out of the back of the indicator switch. Can someone post a picture of the back of the switch. .....or a very detailed description of what wire goes where. Thanks
gaz_powell
unscrew the retaining screw and pull the switch out and down - there should be six wires
working with the wiring black sleeve on the right hand side :-
top row left to right = purple, white/blue, red
bottom row l to r again = white, brown, pink
hope that makes sense
gaz
mick1
It does make sense.....thanks a lot Gaz
Mick
