Carb advice - what size
Posted: Thu Sep 24, 2015 8:56 pm
Ok so I've nearly finished building my 175 engine. Its a SR 175 barrel with some slight tuning/tidying done to it.
It was my intention to fit a 25mm carb to it but I ideally I'd now like to fit that to my 125 Vespa (really I'd prefer a 24mm but I dont want to go and buy another - anyone want to swap?). Anyways a friend has offered my a 26mm that I can fit to my 175. Would that be too big? I'm pretty sure it wouldn't as I remember when I was specing the engine up about 10 years ago the motivation for 25mm was that it allowed me to still use the original air filter. I'm led to believe there are good alternatives available now that mean I could fit the 26 and still keep the panels intact and have an air filter? Cheap ones, not the modified air intake...
Also would I need to change the inlet manifold if I was changing from 25mm to 26? Again I kind of assume not? In the picture below the 25 is the bottom one. Would I need a different one of the rubber attachments to fit to the manifold?
