Thanks Ian
FINAL DRIVE RATIO TV175 BOX
idc23
- Main scooter: lambrettatv175 3
I am going to change gearing tv175 box, with 15x47 sprockets, Mugello 186, phbh 28, jl3 .The jl3 is going to be swapped for a Af 42mm clubman, going back to a 26 phbh, going to drop down to a 14 front, it runs out of puff in top as it is , i want something with more torque, i do some 2 up sometimes.The final drive ratio is 4.92, if i use a 14 tooth it will come down to 5.27, will this be a better choice, any thoughts please
Thanks Ian
Thanks Ian
dave wheeler
no mate, its going to put a lot of strain on your clutch using such a small front sprocket, if ita a huge problem then you should consider a gp125/200 or li150 box, you could sell the tv box to pay for it
I would happily swap a Li150 gearbox for the TV one. But I would not do that to the fella. Stick with that gear box and 28mm carb, change the exhaust and see how it goes.
I did the C2c a number of years ago on the same gearbox and it flew over the passes and kept up with the 200's on the motorway on the return journey.
Regards Paddy.
Regards Paddy.
- Information
Who is online
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 8 guests
