Am I having a blonde moment?
Posted: Sun Sep 13, 2015 10:35 am
by dave-g
Hi guys
We've just rebuilt a PX engine, new DR kit, bearings, seals etc... The problem is it's very difficult to find the gears and there are massive "neutrals" between every gear! First of all we thought it could be a worn selecter so that's been changed.. I've read that there are different size selecters could this be the problem?
Before we change the cables is it possible the cables are round the wrong way??? Or could it be internal, cruciform?
Re: Am I having a blonde moment?
Posted: Sun Sep 13, 2015 11:49 am
by Norrie Bodge
2nd & 3rd gear cogs in wrong way round maybe?
Posted: Sun Sep 13, 2015 12:07 pm
by dave-g
Thanks Norrie, as far as I know the cogs haven't been turned but good idea.. I'll check if We have to split casings!
Do you know if cables around the wrong way would cause these symptoms?
Posted: Sun Sep 13, 2015 9:14 pm
by carlosfandangles
If cables wrong way then u would know as gears would be wrong way round. Ie pull back and you would be able to rotate thru 2nd 3rd and 4th
Posted: Sun Sep 13, 2015 9:48 pm
by mick1
disconnect the cables and will it rock into gear using a screwdriver to move the selector ?
Posted: Mon Sep 14, 2015 6:55 am
by dave-g
Thanks for reply Mick..Yes it will :?:
Posted: Mon Sep 14, 2015 8:05 am
by mick1
dave-g wrote:Thanks for reply Mick..Yes it will :?:
If you can get all the gears and no "false" neutrals then it looks like a cabling/setting up issue.
