Spanish/Italian panels difference?
Posted: Fri Sep 11, 2015 2:06 pm
by karmsemaj
I'm currently on the look out for some original LI special side panels. I've found some Spanish panels but before I spend the money can anyone tell me if they are the same as the Italian ones and will fit? Don't want to waste my money if they are different, cheers.
Re: Spanish/Italian panels difference?
Posted: Fri Sep 11, 2015 3:03 pm
by bristolmod
the Spanish Special panels are wider to accommodate the slightly different fuel tank.
In practice you won't notice it.
Chris
Posted: Fri Sep 11, 2015 3:12 pm
by karmsemaj
Cheers Chris
Posted: Sun Sep 13, 2015 12:46 pm
by steve c
chris i thought that the spanish and italian were very similar but
the later spanish ones are noticeabley wider with about 10mm extra on the top flat chamfered area, must have been welded in must only be 1978 or so scooters,
regards
steve
Posted: Sun Sep 13, 2015 12:53 pm
by bristolmod
As regards size you'd need to ask my missus!!
I'm not sure re the later Spanish ones- there is a slight difference on the earlier stuff
Posted: Sun Sep 13, 2015 3:19 pm
by steve c
I totally agree with you, I almost brought a set of the later ones but there is quite a difference
