not happy with my old malossi 210
Posted: Thu Sep 10, 2015 8:44 pm
Iv now got to the point where im just not happy with my malossi 210 anymore, its just not nice to ride, its the old style kit and i want a change,
sick of constantly having to be on the power and having to constantly change gear, get caught in the wrong gear and it won't pull, then splutter or bog,
so just wondering what my options are,
I don't want to go back to complete standard p200, but want more of a touring set up, the casings are already matched to the malossi, so was wondering what my options are,
spec of my malossi 210 is as follows -
engine casings ported to match,
phbh 28 running air hose
mmw head
pinasco crank
timing set to 18 degrees
T5 7 spring clutch with 22/68 gearing -
T5 4th gear
SIP performance left hand exhaust
running a sip wide wheel, with over size tyre - 120/90/10,
just wondering if the new malossi sport kit would be better as its power is lower down and has more torque?
also thinking of going back to an si 24 carb instead of the phbh
and look at different clutch as the t5 clutch with uprated spring is a bitch to pull
any ideas or thoughts would be much appreciated
mmw head
pinasco crank
T5 4th gear
