jetting pointer...
Posted: Thu Sep 03, 2015 9:39 pm
by Lam-d
ok need a bit of info for a pal of mine his plug is a tad grey (w27 or b9)but the carb is jetted as per recommendations from "tuner" what would you suggest we check or change ... It a 25 mm (through airbox )on an RT225 with Ancillotti pipe jetting is 98 main 46 idle needle is dp29 2nd clip and atomiser is AQ270 any suggestions are greatful ..
Re: jetting pointer...
Posted: Fri Sep 04, 2015 12:39 pm
by dave wheeler
the best way is to go up about 115-120 on the main so it 4 stokes badly, then work down until it runs clean and id stick with that, your atomiser seems rather large as well, my set up on a tv175, standard apart from 24mm phbl and sito clubman through a baffleless airbox but with filter is 100 main, aq 264, d22 3rd notch needle, 48 pilot and 60 choke, the last 2 are too big but i can work round them and like it running cool on over run
