play in rear wheel 1970 gp150
Posted: Sun Aug 30, 2015 1:19 am
by li mick
i suppose there must be some play but how much is acceptable?
Re: play in rear wheel 1970 gp150
Posted: Sun Aug 30, 2015 10:18 am
by bristolmod
"some" play is acceptable and indeed probably required to allow for expansion when warm.
If you rock the rear wheel backwards and forwards top to bottom or side to side, you should just detect a very small amount of play- if its a lot of play then its either the bearing worn; the cone/hub worn; the rear hub nut not torqued up enough or the gearbox end plate loose.
There is mention, I think, in the original 1960's WSM regarding this
Chris
Posted: Sun Aug 30, 2015 9:16 pm
by li mick
thanks chris,its always worth checking.
