This aint right is it
Posted: Sat Aug 29, 2015 3:56 pm
by Snails
Bearing should be flush to the casing shouldnt it?
Forgot to fit the retaining plate when I last refitted the layshaft :(
Just want to check before I strip it all down again. :(
Re: This aint right is it
Posted: Sat Aug 29, 2015 6:05 pm
by rosscla
Most protrude a little but that looks like too much to me.
Did you knock the layshaft in, without the retainer in place that might have moved it.
Give it a tap round and see if it goes down or sounds solid.
Posted: Sat Aug 29, 2015 8:03 pm
by Snails
It does sound fairly solid having given it a few taps. Does not seem to have moved any. I'm wondering whether it would anyway what with the gearbox and clutch assembled....
The other odd thing is that if I try to fit the oil seal the inner lip is always pushed out.
Posted: Sat Aug 29, 2015 8:20 pm
by HxPaul
Wrap the inner bearing race with cling film,lubricate with oil and slide the oil seal over it. :)
Posted: Sun Aug 30, 2015 2:09 pm
by Snails
Tried that and no help, the thing is, the seal seems much wider that the gap I am trying to push it into. No other seal is this difficult to fit....
Posted: Sun Aug 30, 2015 2:11 pm
by Snails
Posted: Sun Aug 30, 2015 3:24 pm
by fairspares
take the layshaft back out , heat the casing area and take the bearing back out first and check it is clean with no swarf or lumps stopping the bearing going in , apply a little heat and refit the bearing you can even smear a thin amount of grease around the bearing outer edge to help in go in , i always heat the casing around the bearing area to reduce the chance of any damage but some dont, then smear grease or oil around the bearing edges were the oil seal fits then tap it in gently and even all around if you dont have a socket big enough or a tool to fit the seal, then fit the retaining plates before you put the layshaft back in. remember to fit the o ring on the layshaft and again smear grease or oil around the o ring and it should either just push in or need a gentle tap .
ah looking at your last pic have you now got the bearing in , if so taking the layshaft out will help with getting the seal in.
Posted: Sun Aug 30, 2015 9:04 pm
by HxPaul
The seal is the right size,the lip needs to go over the inner race.Try using the neck of a plastic bottle.Slice the bottle to make it the correct size to fit on the race,lubricate it and slide the seal over the neck and up on to the race,then tap into position.
Posted: Tue Sep 15, 2015 10:54 am
by Snails
Tried to do that but could not get a bottle cut to the right size, as the necessary diameter always seemed to at the join point of the bottle to the spout if you get me. Anyway I think the problem is because it does not have a chamfered edge so I have bit the bullet and replaced it for one that does.
Posted: Tue Sep 15, 2015 8:50 pm
by joespeed
cut a piece of plastic milk carton to assist in fitting the rear oil seal,not the bottle neck! just roll the carton plastic material place over the inner race and slide the oil seal into place using oil to help lubricate as you slide it home.simples!
