Hub nut
Posted: Fri Aug 28, 2015 12:27 am
by rosscla
Any tips for getting the rear hub nut off an engine on the bench?
And yes, I know I should have loosened it when it was in the frame with the brake cable connected. :roll:
Re: Hub nut
Posted: Fri Aug 28, 2015 6:57 am
by eden
Make a wheel holder using an old rim with a bar welded to it.
Re: Hub nut
Posted: Fri Aug 28, 2015 10:51 am
by rosscla
That's on my 'to do' list as I have a similar tool I made for Lambretta hubs but at the moment I can't find any spare Vespa rims in the shed...
I was hoping to rob the brake shoes out of the spare motor and stick them in the pig and take a pootle down to Millport this afternoon though...
Re: Hub nut
Posted: Fri Aug 28, 2015 12:19 pm
by rosscla
Found a set of shoes loose in the shed so Cinderella might go to the ball after all...
Re: Hub nut
Posted: Fri Aug 28, 2015 5:43 pm
by wack 63
The Lamby holder should hold it providing the nut isn't seized on. Fit the holder onto a hub stud and fit a nut then give the socket wrench a sharp jab with your palm and it should come undone. To save space when you make a Vespa holding tool from an old rim, drill extra holes to match a Lamby hub.
Re: Hub nut
Posted: Sat Aug 29, 2015 2:48 pm
by rosscla
I tried the Lambretta one but bent it as it didn't fit quite right and the engine rolling about on the bench. It shouldn't be seized as the engine has only done about 80 miles since it was rebuilt last, but it's bloody tight.
I'll make a proper tool when I have time now the urgency has gone. Thanks for the suggestions.
Re: Hub nut
Posted: Sat Aug 29, 2015 6:23 pm
by coaster
Put an electric Impact Gun on your xmas list, you'll wonder what you did without it 8-)
Re: Hub nut
Posted: Sat Aug 29, 2015 7:07 pm
by rosscla
How much do you need to spend to get a half decent one? Recommendations?
I did look but most seemed to have a 1/4" drive or lowing torque ratings and £200 plus ones seemed overkill for the odd time I would need it.
Re: Hub nut
Posted: Sat Aug 29, 2015 9:33 pm
by wack 63
If you've got a compressor you can pick an airline buzz gun up for £15
