Page 1 of 2
nickel plating
Posted: Thu Aug 27, 2015 5:50 pm
by hendy
Not sure how useful this is to anyone, but as much as anything else, this makes me feel a little bit sexy.
Nickel plated BGM clubman; phwooaarr
No idea how durable it's going to be as I've never tried it before. I'll report back after I've given it a go.
Re: nickel plating
Posted: Thu Aug 27, 2015 6:15 pm
by monument7
I'll have it when you throw it away
Re: nickel plating
Posted: Thu Aug 27, 2015 6:58 pm
by Grumpy225
Looks like ceramic in the photo. The box its self should hold up well. The header pipe will discolor from the heat though.
Re: nickel plating
Posted: Thu Aug 27, 2015 7:15 pm
by hendy
Grumpy225 wrote:Looks like ceramic in the photo. The box its self should hold up well. The header pipe will discolor from the heat though.
Yes, I expect heat discolouration, and don't mind it at all, but I'm slightly concerned about how well it remains adhered as it was electroless plated. I get all my fasteners, clips etc done this way, but they don't get hot. We'll see.
Re: nickel plating
Posted: Sat Aug 29, 2015 6:44 pm
by carlos fandango
I thought about doj g this on a RM clubman ive got .
I did think it woulx just burn ofc the down pipe though ??
Id be interested in seeing it after a few hundred miles
Re: nickel plating
Posted: Sat Aug 29, 2015 8:09 pm
by hendy
I did intend to put this straight onto my gt186 and report back how it held up, but I'm taking delivery of a winter model on Tuesday that I've decided to keep it for.
The winter model is intended to be a long term project (2 years or so), so unfortunately it'll be a while before I can give any useful feedback.
Re: nickel plating
Posted: Tue Jul 05, 2016 7:15 pm
by hendy
carlos fandango wrote:I thought about doj g this on a RM clubman ive got .
Here it is after "a few hundred miles". I can't be any more accurate than that as my speedo stopped working last summer. The chap who did it said that it might burn off but he'd never tried it before. Anyway, it's worked for me.
Possibly worth noting that it was electroless plated. I've no idea if that affects its durability or not.
Re: nickel plating
Posted: Wed Jul 06, 2016 9:14 am
by Burnside
How does the cost of nickel plating compare to ceramic? Very similar finish to my cermakromed BGM clubman, which is still good after 3 years of all weather riding, iirc that cost me around £130 but I did have a couple of small parts done at the same time.
Re: nickel plating
Posted: Wed Jul 06, 2016 11:03 am
by a.lo.v2
i have recently bought a casa curly exhaust that has a nickel plated finish although it is a gold tinge to it, looks good and surely better than paint. ill see how it holds up. if it is a cheaper option than chrome then it would work, if not than i would have chrome all day long
Re: nickel plating
Posted: Wed Jul 06, 2016 12:31 pm
by hendy
It only cost me £50 but I pass his workshop on my way to work and drop it off. I suspect it doesn't go through the books.
It doesn't look as nice as chrome, but is far better at corrosion protection. That said, a good chrome plater applies nickel before chrome plating. Not always though and chrome on bare steel lasts about 5 minutes.
