6305 Driveside Bearing
Posted: Thu Aug 27, 2015 5:32 am
If you are using the bearing with fitted oil seal (SKF / MB) do you still use the halite gasket between the plate ?
YesBoreham wrote:If you are using the bearing with fitted oil seal (SKF / MB) do you still use the halite gasket between the plate ?
