Dodgy LT coil?
Posted: Sat Aug 22, 2015 1:42 pm
by phil23fair
My scooter generally starts first or second kick. I came home from a ride a couple of weeks back where in the last couple of miles there was a bit of a stutter in the revs which I didn't think too much of because it picked up and was fine the rest of the way home. Went to go out a couple of days later and it would not start. I had fuel and a spark. The compression seemed a bit low so I took off the top end. Everything seemed OK except the ring gap which was about 3mm so I replaced the rings and it still won't start. The spark still seems good but I checked the LT coil resistance and it is 350 ohms instead of the expected 450. Could this be the problem? I would have thought if I had a spark the scooter would have at least tried to start
Re: Dodgy LT coil?
Posted: Sat Aug 22, 2015 2:39 pm
by rosscla
350 is too low - try a known good stator
Re: Dodgy LT coil?
Posted: Sun Aug 23, 2015 8:31 pm
by olliewtf
same thing has just happened to mine. my reading was 360. had a spark, would occasionally fire after a trillion kicks but not last for long.
pulled stator and lt coil was clearly knackered.
so swap lt coil or change whole stator.
Re: Dodgy LT coil?
Posted: Mon Aug 24, 2015 8:25 pm
by phil23fair
Thanks for your replies. It was the LT coil that was faulty. Just replaced it with a BGM one and it started 3rd kick :D
Just goes to show even if you have got a spark it doesn't mean it will start
Re: Dodgy LT coil?
Posted: Mon Aug 24, 2015 9:00 pm
by olliewtf
having said that couldnt believe the price of a bgm LT coil.... 40 quid??!!
Re: Dodgy LT coil?
Posted: Mon Aug 24, 2015 9:17 pm
by Architecten
You could have got the whole stator for 74 quid...?!?!
Re: Dodgy LT coil?
Posted: Mon Aug 24, 2015 9:38 pm
by coaster
olliewtf wrote:having said that couldnt believe the price of a bgm LT coil.... 40 quid??!!
Are you sure that's not for bothe the coil AND pickup? It was a year or so back if Inremember correctly
Re: Dodgy LT coil?
Posted: Mon Aug 24, 2015 9:47 pm
by phil23fair
£18 from Torbay Lambretta
Re: Dodgy LT coil?
Posted: Mon Aug 24, 2015 11:57 pm
by coaster
phil23fair wrote:£18 from Torbay Lambretta
Yes,that's more like it 8-)
