flywheel
Posted: Sun Aug 16, 2015 7:16 pm
by jbg584
Hi
pins on my flywheel on series2 have come forward and jammed motor have got flywheel, of can the pins be replaced if they can be removed or does it mean another flywheel
Ray
Re: flywheel
Posted: Sun Aug 16, 2015 8:02 pm
by rosscla
Not clear what you mean by pins?
If you mean the rivets holding the flywheel to the boss, then they can be drilled out and replaced with high tensile bolts.
Re: flywheel
Posted: Sun Aug 16, 2015 11:51 pm
by jbg584
Hi 4 pins that secure flywheel fan to flywheel
Re: flywheel
Posted: Mon Aug 17, 2015 1:11 am
by bazza3004
What k8nd of flywheel is it eg elec or points Li or GP taper . I may have a spare you can have.
Re: flywheel
Posted: Mon Aug 17, 2015 12:34 pm
by jbg584
Hi bazza3004
Its a 1960 series 2 standard 4pole been on scoot since I bought it in 1960 appreciate if you can help
Re: flywheel
Posted: Tue Aug 18, 2015 2:31 am
by bazza3004
Hi jbg584 ive sent you a pm.
