crankshafts
Posted: Thu Jun 18, 2009 11:29 am
by joespeed
i have looked back under other threads but cant find this, i have several cranks with duff big ends,is there a supplier out there that can supply a good quality offset b/e pin and yam .rod to suit the indian webs? i was hoping to get a bit of extra stroke and a new good quality rod at the same time use up some fair crank bits!
regards
joe
Re: crankshafts
Posted: Thu Jun 18, 2009 1:05 pm
by AUSSIE
readspeed do offset big end pins. They are quite dear because alot of engineering work to make them! I believe the offset is 1mm so it increases stroke by 2mm. Yam RD350 and RD400 rods will fit normal 16mm gugeon pins. the 350 is 110mm and 400 is 116mm
Re: crankshafts
Posted: Thu Jun 18, 2009 7:37 pm
by mark
taffspeed do them as well . ;)
Re: crankshafts
Posted: Thu Jun 18, 2009 10:45 pm
by joespeed
thanks for the reply s,will try them tomorrow,
regards
joe
Re: crankshafts
Posted: Fri Jun 19, 2009 1:42 am
by byron
AUSSIE wrote:... 400 is 116mm
115mm to be pedantic :geek:
Re: crankshafts
Posted: Fri Jun 19, 2009 5:37 am
by J1MS
Thats what I thought, but I didnt want to appear pedantic... :)
Re: crankshafts
Posted: Sat Jun 20, 2009 1:13 am
by byron
:lol:
Re: crankshafts
Posted: Sun Jun 21, 2009 5:32 pm
by AUSSIE
thank you guys for putting me right :oops: , Its good to get the correct infomation :D
