Drive side gearbox bearing
dave411
Main scooter: Li 125
quick question,is this bearing meant to protrude out of the casing? (on the outside)
TA.
most do but usually by less than 1mm
dave411
That's about it,just seems strange that when you put the retainer on it dosent bolt down flush.
if you bolt it down too hard, then you can bend the plate.
