Cylinder head cowling
Posted: Sat Aug 08, 2015 3:09 pm
by Geocamper
Went out for a spin on Thursday and after about 60 miles I noticed a rattling from under the seat. When I checked the cylinder head cowling was loose. I nipped up the two screws Which go into the flywheel cowling. The cowling is still a little loose and rattling against the inlet manifold. It's a Indian Gp 200. I can't see any other holes where I can put a screw to stop the vibration. Should there be more than two holes to keep the cowling in place?
Re: Cylinder head cowling
Posted: Sat Aug 08, 2015 4:03 pm
by Adam_Winstone
An 8mm bolt should go through the front of the cowling into an extended cylinder head nut.
There should also be fibre anti-rattle pads on the inside of the cowling too but these are left out on most rebuilds and are not strictly necessary.
Some Indian cowlings actually come with holes for 2 M8 bolts through the front onto extended head nuts, which does suggest that even manufacturers are aware of the frequency of these coming loose.
Posted: Sat Aug 08, 2015 5:35 pm
by Geocamper
Cheers Adam. Found the 8mm bolt at the front of the cowling. Looks like the cowling around the bolt had worn proberly due to vibration so I added a washer. Everything nice and tight again. Cheers
Posted: Sun Aug 09, 2015 12:32 pm
by shocky
Geocamper wrote:Cheers Adam. Found the 8mm bolt at the front of the cowling. Looks like the cowling around the bolt had worn proberly due to vibration so I added a washer. Everything nice and tight again. Cheers
I normally weld a repair washer as standard for that reason
Posted: Sun Aug 09, 2015 2:59 pm
by Geocamper
Good idea
Posted: Sun Aug 09, 2015 6:03 pm
by Donnie
but if you do it properly in the first place with a bolt and washer it wouldnt be loose and cause the problem?
Posted: Sun Aug 09, 2015 8:22 pm
by Geocamper
You want to tell that to the fella that rebuilt the engine and put the bits back together. This was all done before I bought it which as you may agree/Not agree is totally out of my hands.
