Page 1 of 2
remote air filter position
Posted: Sat Aug 08, 2015 3:05 pm
by dave wheeler
has anyone done any work on tempretures under the panels? Most bikes seem to have their remote filters in the upright position of a standard air hose, but surely theair is cooler and fresher at a 2.00 oclock postion, nearer the fan cowling, does it even matter? any thoughts?
Re: remote air filter position
Posted: Sat Aug 08, 2015 5:51 pm
by db67
Mine is at a " 3 o'clock " position facing the rear, runs just fine
db67
Posted: Sat Aug 08, 2015 8:42 pm
by Timbo
db67 wrote:Mine is at a " 3 o'clock " position facing the rear, runs just fine
db67
Mines the same but only because it won't fit anywhere else....
Posted: Sun Aug 09, 2015 7:38 am
by dennis
Are these positions with a standard manifold or are you using a rimini maxi flusso manifold,if it's a standard manifold has anyone used the rimini manifold and is it any better for filter position?.
Posted: Sun Aug 09, 2015 7:55 am
by Timbo
Short MB one on mine Dennis......if you have a standard tank they will fit where the air box was otherwise it's at 3 o'clock...or 2.10....
Posted: Sun Aug 09, 2015 6:02 pm
by Donnie
mines in the same position as standard ie at 12 o clock, if its anywhere else your either wrong or using the wrong item or falling for some marketing hype
Posted: Sun Aug 09, 2015 9:39 pm
by Train Driver
Donnie wrote:mines in the same position as standard ie at 12 o clock, if its anywhere else your either wrong or using the wrong item or falling for some marketing hype
Some of us like a bit of hype
Posted: Sun Aug 09, 2015 10:36 pm
by Donnie
Oh and the hype loves you for sure, get your cheque book out at the slightest hint of a new product that might be the next big thing.
So many (not all) seem more form over substance especially when it comes to longevity.
Posted: Sun Aug 09, 2015 11:55 pm
by rosscla
The orientation of the filter shouldn't make any difference to the function as long as it has free flow of air.
Posted: Mon Aug 10, 2015 7:26 am
by db67
Totally agree with you rosscla, its all about obtaining the best airflow, had a major heat seize running it at the 12 o'clock position going to mersea island one year ,we put it down to the fact that it was right above the cylinder cowling breathing hot "dirty" air, as on a standard set up the filter box relies on cool air coming from the scoop, i ran it the rest of the way at the 3 o'clock position & all the way home again without another problem! have ran this way ever since, seems to work for me. db67
