Cylinder stud holes
Will this leak into the cylinder stud hole
Sent from my C5303 using Tapatalk
holty
Main scooter: lambretta gp
if you fit the stud with studlock, it should seal it, what is it, i cant tell from the close up picture ?
wack 63
Main scooter: '71 GP TS1
Needs welding and skimming.
Grumpy225
Given the general condition of that case I'd have it blasted clean before I spent any money on it getting it repaired.
Its been cleaned now and thats the only fault its an early sil 150 casing and going off for a 200 conversion thanks for the interst ;)
gaz_powell
is it going to be converted to 200 stud spacing and spigot to take a 200 barrel or a just a 200 kit on the same casing
if its a casing conversion they would pick that up in the work for a small addition
Yes gaz 200 spigot conversion I can say were its going ...
