kickstart oil seal
Posted: Thu Aug 06, 2015 7:19 pm
by essexgp
Help, just rebuilt my clutch and decided to replace the kickstart oil seal, took it out now cant remember which way it goes in
Does the seal fit with the spring side out or facing in?
Re: kickstart oil seal
Posted: Thu Aug 06, 2015 7:24 pm
by Grumpy225
in
Posted: Thu Aug 06, 2015 7:25 pm
by essexgp
Thanks, now how do you get it in without the spring coming off which is the trouble im having
Posted: Thu Aug 06, 2015 7:47 pm
by essexgp
All sorted!
Posted: Thu Aug 06, 2015 8:00 pm
by Grumpy225
For general info, you can use a special sleeve that fits over the kick shaft teeth. Grease it up and slide it in the hole, remove sleeve and install shim/circlip. Or carefully start the seal down the shaft and use a small tipped screwdriver to lift the seal edge around the teeth.
Posted: Fri Aug 07, 2015 8:35 am
by wack 63
I use a piece of plastic pop bottle rolled around the shaft, grease and slide the seal down then pull the sleeve out.
