Cylinder stud holes
Posted: Tue Aug 04, 2015 10:39 am
by shocky
Will this leak into the cylinder stud hole
Sent from my C5303 using Tapatalk
Re: Cylinder stud holes
Posted: Tue Aug 04, 2015 12:55 pm
by holty
if you fit the stud with studlock, it should seal it, what is it, i cant tell from the close up picture ?
Posted: Wed Aug 05, 2015 6:26 pm
by wack 63
Needs welding and skimming.
Posted: Wed Aug 05, 2015 8:30 pm
by Grumpy225
Given the general condition of that case I'd have it blasted clean before I spent any money on it getting it repaired.
Posted: Thu Aug 06, 2015 10:00 am
by shocky
Its been cleaned now and thats the only fault its an early sil 150 casing and going off for a 200 conversion thanks for the interst
Posted: Thu Aug 06, 2015 10:02 pm
by gaz_powell
is it going to be converted to 200 stud spacing and spigot to take a 200 barrel or a just a 200 kit on the same casing
if its a casing conversion they would pick that up in the work for a small addition
Posted: Fri Aug 07, 2015 12:32 am
by shocky
Yes gaz 200 spigot conversion I can say were its going ...
