Page 1 of 2
Thanks for all the help, 1st engine build complete!
Posted: Mon Aug 03, 2015 9:41 pm
by alanscottj
As it says, thanks for everyone's help and of course Sticky's wonderful book, I have finally finished my first ever engine build. Using a casing purchased from Scooterotica I have put together a TS1-225 and I think it looks the biz. I've followed the book to the letter, made a couple of mistakes (one rather costly, but hey ho!), everything is loctighted down and tolerances adhered too, gearbox is moving nice and smooth, just the squish to check and she'll be ready to fire up :D
Again, many thanks for everyone's help. Can't wait to fit her and fire her up......has anyone got any jetting suggestions for a 30mm Delly and Jl3 pipe ;)
Re: Thanks for all the help, 1st engine build complete!
Posted: Mon Aug 03, 2015 10:21 pm
by HxPaul
It may just be the light on the photo,but it looks like you haven't fitted a flywheel nut.
Posted: Mon Aug 03, 2015 10:49 pm
by alanscottj
HxPaul wrote:It may just be the light on the photo,but it looks like you haven't fitted a flywheel nut.
I haven't yet, well spotted, waiting for a new one :D
Posted: Tue Aug 04, 2015 1:01 am
by corrado
....... and don't forget that it tightens anti clockwise.
Posted: Tue Aug 04, 2015 6:06 am
by Toddy
Well done , hope it runs well :D
Posted: Tue Aug 04, 2015 8:09 am
by wack 63
Pressure test before fitting would be a good thing, I've had several leak on the inlet manifolds with the gaskets they supply nowadays.
Posted: Tue Aug 04, 2015 9:19 am
by alanscottj
Toddy wrote:Well done , hope it runs well :D
Thanks Toddy, I just hope it runs' :lol:
Posted: Tue Aug 04, 2015 9:21 am
by alanscottj
[quote="wack 63"]Pressure test before fitting would be a good thing, I've had several leak on the inlet manifolds with the gaskets they supply nowadays.[/quote
I'm going to get a tyre inner tube from Halfords and try that method :)
Posted: Tue Aug 04, 2015 9:39 am
by HxPaul
wack 63 wrote:Pressure test before fitting would be a good thing, I've had several leak on the inlet manifolds with the gaskets they supply nowadays.
Can doing a pressure test cause problems if the cylinder to head gasket doesn't leak under the test situation (max pressure 7psi) but when running it begins to leak because the pressure in the cylinder head combustion chamber is much higher ?
Posted: Tue Aug 04, 2015 8:16 pm
by alanscottj
Got her fitted and tested earlier today, here's a littl video of her first start up. Well happy :D :D
http://vid1298.photobucket.com/albums/a ... ihupc7.mp4
