Missing mag side retainer : rebuild??
Posted: Mon Aug 03, 2015 4:57 pm
by alanscottj
After what felt like hours, lots of sweat and a bit of swearing, I finally managed to get my Mag housing bearing and seals into place. Fitted the mag housing to my new engine and fitted stator plate etc etc only to walk into the shed and find the l shaped reatainer on the side!!!! Obviously I realise it does a job, but, I really don't want to try and get this bearing out again, even heated up it was a bugger to get in. Will I get away with it until I get chance to fit it?
Re: Missing mag side retainer : rebuild??
Posted: Mon Aug 03, 2015 6:11 pm
by dapper
No, its there for a purpose. I'm afraid a strip down again of the mag housing is required, unless you've changed from an LI/SX type crank to a GP style crank, as it's not needed on the GP style crank.
Posted: Mon Aug 03, 2015 6:14 pm
by alanscottj
dapper wrote:No, its there for a purpose. I'm afraid a strip down again of the mag housing is required, unless you've changed from an LI/SX type crank to a GP style crank, as it's not needed on the GP style crank.
It is a GP style crank......
Posted: Mon Aug 03, 2015 6:28 pm
by Grumpy225
You're thinking about the spacer ring for the thinner SX/LI style bearing (NU205). GP uses the NU2205 and is wider
If I remember right the L cup helps keep the outer seal in place. You need this one in there.
Posted: Mon Aug 03, 2015 6:53 pm
by alanscottj
Grumpy225 wrote:dapper wrote:No, its there for a purpose. I'm afraid a strip down again of the mag housing is required, unless you've changed from an LI/SX type crank to a GP style crank, as it's not needed on the GP style crank.
I knew someone would spoil it for me!
I've just been to Halfords and bought a blow torch. Hopefully I can get the bearing out to re-use
Posted: Mon Aug 03, 2015 7:18 pm
by HxPaul
Take the circlip off and prise out the oil seal (you'll need to get a new one)Put the mag housing on the hob and heat it up until the bearing drops out,quickly fit the L shaped washer and the bearing.Fit the new oil seal and circlip when the mag housing has cooled enough,pack the bearing with high temp grease.Make sure you fit the L shaped washer the right way up,with the flat side towards the seal and the othe side towards the bearing.
Posted: Mon Aug 03, 2015 7:48 pm
by alanscottj
HxPaul wrote:Take the circlip off and prise out the oil seal (you'll need to get a new one)Put the mag housing on the hob and heat it up until the bearing drops out,quickly fit the L shaped washer and the bearing.Fit the new oil seal and circlip when the mag housing has cooled enough,pack the bearing with high temp grease.Make sure you fit the L shaped washer the right way up,with the flat side towards the seal and the othe side towards the bearing.
All done! Using a proper blow torch made it sooooo much easier, the bearing just dropped out! Got the L plate retainer on (the right way!) Looks like it'll be a while till I can fit it to engine, boy it's hot!!!!
Thanks for all advice as always, most appreciated
You can tell it's my first engine build eh?
Posted: Mon Aug 03, 2015 10:04 pm
by Yanker
I hope your mag bearing's plastic cage survived the heat treatment (if that is appropriate and it is not a metal cage variant)
Posted: Mon Aug 03, 2015 10:06 pm
by alanscottj
Yanker wrote:I hope your mag bearing's plastic cage survived the heat treatment (if that is appropriate and it is not a metal cage variant)
The bearing and casing 'looked' ok, I'll soon find out
