head gasket blowing
yozzer
Main scooter: gp200
I`ve got my head gasket blowing on my gt 186, I normally jut smear grease over both sides of gasket for ease of removal later but think I need a sealant now so any recommendations ie Loctite or silicone ?
gaz_powell
stag wellseal or yamabond for me
edit
\/\/\/ agree with that - but that's second nature to me (do barrel and head)
bristolmod
I'd be looking at the "flatness" of the head mating surfaces first.
Chris
Scootering since 1968.
yozzer
Main scooter: gp200
yeah I know what you mean bristolmod but it was ok before taking it off, if I get it skimmed would prob need a thick gasket
bristolmod
just work it on a bit of wet and dry on a flat surface (sheet glass etc)- shouldn't affect it compression wise to any real degree.
Chris
ducksta
bristolmod wrote:just work it on a bit of wet and dry on a flat surface (sheet glass etc)- shouldn't affect it compression wise to any real degree.
Chris
the sheet of glass is a old wifes tale, get a piece of steel from your logal engineers tell them what you want it for they will cut and skim a piece.
bristolmod
float glass is perfectly flat- steel does bend......
ducksta
6mm piece of steel is easy to get hold of and keep in the workshop, a perfect pice of glass that you could break is hard to find
yozzer
Main scooter: gp200
i do have a table saw will solid steel top on it which is about 50mm thick, maybe that would work
Tempered glass chopping board with fine valve grinding paste and WD40 does it for me.
