Page 1 of 2
Clutch basket catching on side casing? help!
Posted: Tue Jul 28, 2015 9:24 pm
by alanscottj
Re: Clutch basket catching on side casing? help!
Posted: Tue Jul 28, 2015 10:31 pm
by Chris in Margate
What side casing and clutch operating assembly are you using?
Posted: Tue Jul 28, 2015 10:42 pm
by alanscottj
Chris in Margate wrote:What side casing and clutch operating assembly are you using?
A GP side casing, I haven't fitted the clutch arm etc yet.
Posted: Tue Jul 28, 2015 11:44 pm
by shocky
Is it a 5 plate spider ?
Posted: Tue Jul 28, 2015 11:50 pm
by shocky
Did you check how much the spider pokes through the sprocket on the back shouldn't be more than 0.10mm (a tenth of a mm) also did ypu check the sprockets were at the same hight what thickness shim is under the spider ?
Posted: Wed Jul 29, 2015 8:18 am
by alanscottj
shocky wrote:Is it a 5 plate spider ?
No, well, I asked for a standard one at the parts fair. There are 5 plates as I bought a 5 plate set up that allows you to keep a standard spider.
Posted: Wed Jul 29, 2015 8:30 am
by shocky
Ahhh parts fair special then I suggest it's to tall which is typical of the cheaper ones which I believe are for a lambro how tall is it in total?
Sent from my C5303 using Tapatalk
Posted: Wed Jul 29, 2015 8:57 am
by alanscottj
Ok, taken it all apart, removed all the shims and checked the lay shaft was fitted all the way in. Put it all back together without any shims and the spider is still sitting to high. When I put the casing on it touches the top of the spider ever so slightly.
It's either:
Clutch spider is wrong size
End plate bearing wrong somehow: too thick? Making the spider sit slightly too high?
Side casing somehow wrong, but it fits on my other engine perfect?
Posted: Wed Jul 29, 2015 9:07 am
by alanscottj
Took the end plate off, fitted spider and casing sits perfect.
Posted: Wed Jul 29, 2015 9:37 am
by Muppet
build it without the springs and take a look
