socks
Posted: Sun Jul 26, 2015 8:45 pm
by Greg Casey
Bit of a Div question .. but im very new too scooters .. on my rear suspension i have a damper and besideit is the suspension spring but there should be something inside the spring top and bottom comming out of the shock plates too stop the sping falling out... can someone plz tell me what they are called so i can try order a set.. its a 1966 j125
Re: socks
Posted: Sun Jul 26, 2015 10:09 pm
by lambro
Socks
http://www.scooterrestorations.com/lamb ... uspension/
Some parts mentioned on here, a quick phonecall to Scooter Resto's will get you the parts you require
Shaun.
Re: socks
Posted: Sun Jul 26, 2015 10:15 pm
by lambro
I converted my last J rear suspension like this:
I made a spacer for the lower mount to take up the width difference between a Vespa smallie and the J, other than that a bolt on conversion.
Rear J dampers are quite pricey, and this Smallie shock was only a fiver
It looks close to the engine case, but when it was sat upon there was loads of clearance.
Much better than the fecked shock that was on there.
Shaun.
Re: socks
Posted: Sun Jul 26, 2015 10:27 pm
by Greg Casey
socks ...lol... oh my god lmao... just seen it now.. thanks sean nice job ..
Re: socks
Posted: Sun Jul 26, 2015 10:30 pm
by Greg Casey
nice info lambro thanks
