GP Street Racer Build
Posted: Sat Jul 25, 2015 12:25 pm
It started 18 months ago when i visited Scooter Restorations in Notts, a tour of the new warehouse yielded a boxed new early frame (number 001!) tucked away, i went for a few bits and left with a brand new frame, panels and a SIL factory engine!, expensive day out.
What started as an initial build to produce a 'new' std GP for rallies ended up being something slightly different, maybe my many years rallying historic cars felt the need for a bit more.....
A dry build of all the sourced panels was the best advise i had, even with a mix of new SIL and genuine panels meant everything needs slight adjustments, a good tip is time spent here gives a much easier final build, particularly on the leg shields, drill everything and double check.
A decision on the final design and colour was a long winded search, do you stick to the traditional colours or go different?? hmmm, i finally decided on the Lechler 8059 Bianco, slightly odd i agree but the optic white just looked a bit, well, bright!
I was in a lucky position that my fried runs the sprayshop for a BMW dealer, so sneaking in the panels after hours was the order of the day, bit difficult with the frame, the results was excellent.
Let the dry build begin.............
