Page 1 of 4
New engine build TS1 questions....
Posted: Thu Jul 23, 2015 9:09 pm
by alanscottj
I have started my new engine build with the casings that I got off Scooterotica, made up with them tbh. I have managed to fit all bearings and studs. All is well, but, when I put the rear hub bearing oil seal in it restricts the bearing, I can only JUST spin the bearing round with my finger. Is this normal? Will it wear in when the engine is moving or have I done something wrong? P.s. I have just removed the seal that's why it's not seated properly
Re: New engine build TS1 questions....
Posted: Thu Jul 23, 2015 9:37 pm
by tarmac tickler
normal resistance pal till its spinning and worn in,, crank will be the same
Posted: Thu Jul 23, 2015 9:40 pm
by alanscottj
tarmac tickler wrote:normal resistance pal till its spinning and worn in,, crank will be the same
I thought so
plus I haven't greased it yet
thanks
Posted: Thu Jul 23, 2015 9:44 pm
by alanscottj
What I've done so far
All studs loctited it, rear hub bearing fitted, drive side bearing fitted and cylinder studs fitted, not a great deal but little by little
Posted: Thu Jul 23, 2015 9:54 pm
by alanscottj
On the bottom of the skirt, where I have marked in red marker pen, this tiny bit, just the very corners seem to foul the mag housing meaning the mag housing will not sit flush by about 1mm. Or if I put the mag housing on first, then the barrel, the barrel will not sit flush with the base gasket face. Am I ok to Dremel the corners ever so slightly so that they will not protrude?
Posted: Thu Jul 23, 2015 9:58 pm
by Muppet
150 mag housing?
Posted: Thu Jul 23, 2015 10:05 pm
by alanscottj
Muppet wrote:150 mag housing?
Ah, it could well be, it's one I have had laying in the garage for ages, fitted so that I could loctited the studs in. Is there a big difference between a 150 and a 200 housing then? I thought they were the same?
Posted: Thu Jul 23, 2015 10:29 pm
by Muppet
150 spigot would fit in the gap wider 200 wont
Posted: Thu Jul 23, 2015 10:31 pm
by alanscottj
Muppet wrote:150 spigot would fit in the gap wider 200 wont
So I need a mag housing for a 200?
Posted: Thu Jul 23, 2015 10:43 pm
by Muppet
alanscottj wrote:Muppet wrote:150 spigot would fit in the gap wider 200 wont
mag housing dremmel time
