Page 1 of 3
Cast iron VS Aluminium cylinder
Posted: Wed Jun 17, 2009 4:28 pm
by El__burro
What is best Cast Iron or Aluminium cilinder,
Having to choose wich one should I go for (it's a 175cc conversion)
what could the prices be?
Thanks
El__burro
Re: Cast iron VS Aluminium cylinder
Posted: Wed Jun 17, 2009 4:31 pm
by drunkmunkey6969
When they are in stock, AF Rayspeed 175 kits are good value for money, cheap motoring. (£170?)
RB20s are very powerful, but more expensive. (£390?)
MBs RT190 promises to be good when its released. (£500??)
Posted: Wed Jun 17, 2009 5:12 pm
by El__burro
I meant aluminium or cast iron?
thanks
El__burro
Posted: Wed Jun 17, 2009 5:41 pm
by drunkmunkey6969
depends on cash.....but ali is runs cooler.
Posted: Wed Jun 17, 2009 5:47 pm
by El__burro
£75...
Aluminium or Cast Iron?
Thanks
El__burro
Posted: Wed Jun 17, 2009 5:53 pm
by drunkmunkey6969
El__burro wrote:£75...
Thanks
El__burro
cast
Posted: Wed Jun 17, 2009 9:45 pm
by oldbiker
Nicasill lined V cast iron in alloy or cast iron?? simple . In theory a nicasill lined barrel will never need a rebore and has the potential for a little more power due to slightly better cooling. however in practice when a cast iron job needs a rebore it will cost 20 to 30 quid, a nicasill replate will cost 180 to 200 quid. tuning a nicasill lined barrel takes 1/4 the time of tuning a cast iron jobby, as a tight fisted under payed engineer I like cast iron liners in an alloy barrel, if I had unlimmited resourses I would go for a nicasill liner in an alloy barrel or a ceramic lined alloy barrel. Question is 3 to 4 bhp v 200 quid for a repair.
Posted: Wed Jun 17, 2009 10:22 pm
by drunkmunkey6969
For £75......he has little choice.
Posted: Wed Jun 17, 2009 10:28 pm
by sean brady scooters
it may be true that an alloy kit dissipates heat slightly better than a iron one......................................but at the end of the day it does not count for much..........................
most alloy kits now have much less fin area anyway..................
i think its far more important to get your basic set up correct.............rather than worry about cast/verses alloy...................
Posted: Wed Jun 17, 2009 10:40 pm
by El__burro
the point is that i bought a cast iron one on ebay but then the seller told me
that there was a problem with the one i bought and suggested to go for an aluminium one for the same price.
is the aluminium one that bad for £75?
I am not sure if it's a Nikasill plated.
Thanks
EB
