Squeak from engine
Posted: Sun Jul 19, 2015 11:53 am
Thought I'd float this baby !!
Just built a fresh engine. Its a GP 200 indian engine, so I have replaced with all new bearings and seals.....only difference being I have replaced the original 3 ringed piston with a new 2 ringed piston found sitting in me shed. The barrel is non standard, but is a steel barrel with with aluminium fins, (not sure what it is, but like a rapido I guess, although the steel inlet and outlet is poorly cut out to match the outer alloy lining but probably acceptable). Squish is 1.3mms and it has a Jetex 22mm carb.
Put engine back in scoot and it has a squeak a bit like you'd get if the head gasket had a slight leak and the engine is racing a little on idle and whatever I do to the carb to bring it down it has little effect (so thinking air leak). I changed the head gasket but this time added a little sealant to either sides of the head gasket faces. Put bike back together on scoot and it still does it. Wondering if it could be the mag side gasket or even base gasket but no obvious oil leakage.
Any ideas ?
Any ideas ?
