Page 1 of 2
Scooterotica crankshaft ....... Sean? Dan?
Posted: Fri Jul 17, 2015 10:23 am
by corrado
What's the update on the "special " [low crankcase compression?] crank you built a few years ago. Last I heard it was in a customers scoot and going strong.
Have you got a link to the original postings? I thought it was on the scooterotica website tuning pages but it was probably later than that.
Re: Scooterotica crankshaft ....... Sean? Dan?
Posted: Fri Jul 17, 2015 11:41 am
by sean brady scooters
Posted: Fri Jul 17, 2015 3:56 pm
the one that you refer to martin was used in an RB20 ,the chap has now sold it on but only after a few years of running it ..he always remarked about how smooth running it was and how his motor was so responsive ..cant remember his dyno figures exactly but it sure was a healthy thing .
I have done quite a few of these for various folk ,and as far as i know Foxhat still use one in one of their scooters and last i heard from them they said the same things .
Posted: Fri Jul 17, 2015 5:15 pm
The better and easier way now ,when rebuilding a whole engine with lower primary comp is to use longer rods and a packing plate together with std comp height pistons ,this creates more volumne where its needed .although this can be a whole lot more expensive .
we follow this route now on most engine builds we do if we can,but if your going to retain the 107/110 rod
then these crank mods will do pretty much the same thing .
Posted: Fri Jul 17, 2015 7:15 pm
by eden
sean brady scooters wrote:The better and easier way now to lower primary comp is to use longer rods and a packing plate together with std comp height pistons ,this creates more volumne where its needed
that's always been the better and easier way
Posted: Fri Jul 17, 2015 10:31 pm
by Yanker
eden wrote:sean brady scooters wrote:The better and easier way now to lower primary comp is to use longer rods and a packing plate together with std comp height pistons ,this creates more volumne where its needed. we follow this route now on most engine builds we do if we can,but if your going to retain the 107/110 rod
So 115/116mm rod with 39mm ch piston = +9mm. +11mm, + 13mm packer (dependent on stroke) : does that not present a whole s**t storm of problems with frame clearance: fannymould/plug/stand/cowl height/exhaust fitment? (only asking
Posted: Sat Jul 18, 2015 6:24 am
by eden
easier than grinding crank webs imo, Yanker you forgot to mention rear foot boards
Posted: Sat Jul 18, 2015 1:14 pm
Yanker wrote:eden wrote:sean brady scooters wrote:The better and easier way now to lower primary comp is to use longer rods and a packing plate together with std comp height pistons ,this creates more volumne where its needed. we follow this route now on most engine builds we do if we can,but if your going to retain the 107/110 rod
it sure does lol
Posted: Sun Jul 19, 2015 4:41 pm
by Yanker
eden wrote:easier than grinding crank webs imo, Yanker you forgot to mention rear foot boards
And maybe even a longer HT lead? But surely You would not have to do that grinding buisiness? R Taylor/GT crank, hold the 'Paxo' please?
Posted: Sun Jul 19, 2015 9:20 pm
by eden
not long now Yanker
