Engine won't rev..... help!
Posted: Fri Jul 10, 2015 8:07 pm
Evening All,
I've just stripped and rebuilt the top end and added a 30mm phbh Dellorto and TSR EVO exhaust. I've matched the exterior porting to the new manifolds. Scooter is a Harry Barlow/Suzuki 190 conversion. Carb came from Cam Lam with ball park jetting. All was good and it went well straight off the bat, plug colour looked fine etc...
The other night, all of a sudden it started to die, I eased off the throttle and it remained running at low revs but died whenever I tried to open it up. Since then I have stripped the carb to check for blockages and the jets are clear. The rubber mount is fine and not split. I have replaced the ignition switch as this needed doing anyway. Fuel is flowing (new Cam Lam fast flow tap), petrol cap vent is not blocked.
Still it does the same, it's ok for about 200 yards then starts dying again. I have changed the plug. The plug cap is new as is the lead. Choke is not sticking. I did a leak down test when I assembled it. I'm at a loss to know what to look for next, has anyone got any ideas?
Spoke to Cam Lam and they said the jetting may not be spot on but it should be near enough as they've sent it jetted the same as they do for their Imola kits.
It's almos like fuel isnt get through but it must be, take the foam filter off and there's plenty spitting back out but it just won't rev.
I'd be really grateful if anyone could shed any light on what to try next, supposed to be going to a rally for the day tomorrow and I've run out of ideas!
Thanks in advance....
