Clutch side bearing
Posted: Thu Jul 09, 2015 7:48 pm
by stonerosesmod
Just stripped a mates PX200 engine with a malossi 210 as it was running propper rough.The cut crank is basically shagged as it's cracked by the pin so the webs can be twisted by hand.
I found the clutch side bearing had a big amount of play between the casing and circlip,much more than I've seen before.Can this be shimmed when a new bearings fitted or will it be ok?
Re: Clutch side bearing
Posted: Thu Jul 09, 2015 9:01 pm
by rosscla
When you say play do you mean that the bearing was loose in the casing?
Posted: Thu Jul 09, 2015 11:12 pm
by stonerosesmod
Yes about 3mm end float easy and the bearing was moving inside the casing til it hit the large circlip.Im hoping it's a cheap bearing as there's no stamping on it anywhere.Casing where the bearing fits looks undamaged.Took a light tap and the whole bearing fell out the casing without any heat either.
Posted: Fri Jul 10, 2015 6:51 pm
by T5-190
With the cost of a new crank case I would fit a new bearing. De-grease the bearing and the bearing hole and use some Loctite bearing fit or similar. Bearings normaly want to run around their own races than the crank case. Worth a try.
Posted: Fri Jul 10, 2015 8:01 pm
by rosscla
Agreed, it may just be a dodgy undersized bearing (I hope so), but try the loctite if a new quality bearing doesn't fit firmly.
