Die, die, die
Posted: Tue Jul 07, 2015 8:13 pm
by druist
ok bought a casa ignition as I thought my Indian one was had it, it wasn't turning off. It's a Gp 1979 sil, was working fine, but now the same thing happening, not turning off. May have moved wires by mistake, but can't see a loose one on headset or reg. any ideas, also what colour is kill switch?
Thanks ppl
Sil no indicators, electronic ignition (not sure who's), no battery, GP 150 now imola with Augusto timing
Re: Die, die, die
Posted: Tue Jul 07, 2015 8:27 pm
by Tractorman
Green
Re: Die, die, die
Posted: Tue Jul 07, 2015 8:28 pm
by 22/2
Green
The switch allows the green go to earth, have a look at the CDI (if you're electronic) there will a pair of greens next to each other, make sure they are both secure, if the one from the loom is off it will not shut off or in the bulb holder (this is the junction box on a GP) there will be the same pair of greens one switch the other loom, again if one is out you won't make the circuit through the switch.
They are the only two place for ignition - i think.
rich
Re: Die, die, die
by Chris in Margate
Nothing to do with regulator.
Should be 2 green wires connected to CDI. One from stator, one from headset. At the headset end the green wire is earthed when you hit the kill switch. Is the earth to the switch OK?
Re: Die, die, die
Posted: Tue Jul 07, 2015 8:35 pm
by druist
Thanks. After trying that found that the headset pink Earth on ignition was not contacting well on headset screw, little sparks coming off it, that normal?
Re: Die, die, die
Posted: Tue Jul 07, 2015 9:17 pm
by lambro
druist wrote:Thanks. After trying that found that the headset pink Earth on ignition was not contacting well on headset screw, little sparks coming off it, that normal?
Sparks means NOT a good earth.
Clean and resecure, and that should kill the (green) feed and earth it out to stop engine.
