Page 1 of 2
Painting Engine Casings
Posted: Sat Jul 04, 2015 1:43 pm
by DickieD
Afternoon,
A mate of mine has asked me what is the best paint for painting his engine casings. Is standard paint and etch primer good enough or should he use a high temp paint?
If he uses high temp paint is it best to seal with high temp lacquer?
I know powder coating is prob the best way to go but he wants to paint them, has anyone done it and had decent results?
Any tips greatly appreciated.
Re: Painting Engine Casings
Posted: Sat Jul 04, 2015 4:59 pm
by Doom Patrol
I think your friend is probably mad.
Powder coat is by far the best solution and you could probably do it in a variety of colours if you want. I'm not sure I've ever seen an engine that's been painted by hand.
Posted: Sat Jul 04, 2015 6:41 pm
by bristolmod
I did a Hillman Imp engine by hand once in 1975.
Feckin awful mess it turned out
Posted: Sat Jul 04, 2015 7:41 pm
by GBCS
Powder coat, every time.
Posted: Mon Jul 06, 2015 2:11 pm
by GLscoot
Posted: Mon Jul 06, 2015 8:26 pm
by lambrettalad
DickieD wrote:Afternoon,
High temp paint and clear would be fine, make sure that the clear is high temp though as it can go brown in colour.
No reason why paint cant be used, gonna paint mine.
Posted: Mon Jul 06, 2015 9:39 pm
by Muttley McLadd
To paint the case, wouldn't you need to get it pretty clean to start with, or it wont stick? If you've gone to the expense of having it cleaned to a high standard, wouldn't it be just a few sheckles more to get them powdercoated?
Posted: Tue Jul 07, 2015 7:19 am
by mick1
powder coat is the best covering but this will require all the seals and "o" rings to be removed, as the powder coated is finished off in a high temp' oven.
On a total bare casing it's a no-brainer to get it powder coated, if the engine's already built then painting is your only viable option. As to whether to use hi-temp paint, I've used normal paint before with good results.
Posted: Sat Jul 25, 2015 8:29 pm
by philcasino1973
i,ve used this stuff with nice results .....aluma blast by eastwood from frost autorestorations
its a great product
phil
Posted: Sat Jul 25, 2015 9:44 pm
by ducksta
Etch primer and pj1 matt black worked for me not lacaured tho
