Bolt-on Adjustable Powerjet Tube Length
Posted: Sat Jul 04, 2015 9:38 am
Hi All,
Whilst this is a topic that is being covered on another thread (http://scooterotica.org/forum/viewtopic.php?f=7&t=18415), the thread's TMX35 title might put a few people off from looking at it, hence I'm posting a link under a different/generic title as the subjects being covered are applicable to all carbs using these ever more common bolt-on PJs.
I particularly need some input/feedback on brass throttle length and position, based on experience rather than just reiterating what may be quoted on the limited info published elsewhere. The whole other thread is worth a read but the bit that relates to all carbs is....
I've fitted a Camlam add-on PJ and positioned it to reach the centre of the Venturi, which brings in the enrichment way too early, making things too rich at low throttle positions, which is killing performance and progression. Out of interest, I looked at the bellmouth and brass tube length of my old Mk2 Amal and that only reaches half way to the centre of the Venturi, functioning well to enriched the top end only. The difference being that the Amal tube comes in from the top (vertical) and reading up would suggest that this is important as it relates to the air intake being restricted at the top of the Venturi until the slide raises above the brass tube at 3/4 and above. If this is the case then a tube coming in on an angle will influence Powerjet function.
It seems as though I will need to employ a combination of winding out the Powerjet and cutting it shorter, however, I don't want to cut it too short and regret it. What have the rest of you done and have you managed to find any good info/websites?
https://www.ooracing.com/store/carb-bod ... r-jet.html
This link should show another pj carb body with a short brass pj tube, which I understand will bring in enrichment later, but this confuses me slightly as surely the purpose of a pj is to kick in later in the progression range, so why produce a pj with such a long tube? That said the Lectron pj carbs have a tube that comes down to the centre of the Venturi.
Certainly my current tube length, to centre, is causing enrichment to happen way too early on my motor and I'm having to close up the adjustment completely, otherwise it just makes it boggy from less than half throttle upwards!
Edit: I note other 2-stroke fans are asking the same question and it appears as though the vertical nature of the tube is pretty important, which is something not really being addressed in the instructions available. Tube length also very important, with uncovered length relating to enrichment, which would make the middle of the bore position silly if you want the PJ to flow from 3/4 throttle up and support Amal's position of the tube end only 1/4 down into the bore (3/4 throttle position). I realise that there are 2 elements to flow; uncover position and suction rate in venturi but there is little clear info.
