Ignition switch conversion for Li125 S2
Posted: Fri Jul 03, 2015 4:46 pm
by Mike - - Bristol
How easy is it to convert the TV switch to fit an Li.
Rimini have some and I wondered if it was a straight forward change.
Cheers in advance.
Re: Ignition switch conversion for Li125 S2
Posted: Fri Jul 03, 2015 9:10 pm
by HxPaul
I've fitted an ignition switch to my series 2 Li 125.I use the ignition switch for ignition,side light and headlight.I just use the handlebar light switch for dip,main beam and horn.
Posted: Fri Jul 03, 2015 10:24 pm
by Mike - - Bristol
Thanks for the reply Paul.
Did you have to fettle the switch to get it to fit or was it a straight swap.
Posted: Fri Jul 03, 2015 10:28 pm
by lambro
Mike - - Bristol wrote:Thanks for the reply Paul.
Series 2 is a straight fit, I fitted one to my bag o' rust S3 Spanish Special and I had to fettle the inside for clearance,
so much I don't have a steering lock.
Odd, as Italian Specials had them with no issues :?
Shaun.
Posted: Sat Jul 04, 2015 8:42 am
by Mike - - Bristol
Thanks
Posted: Mon Jul 06, 2015 9:18 am
by HxPaul
I had no problems fitting my switch,it went straight into the headset in place of the cutout button.
Posted: Mon Jul 06, 2015 11:42 am
by Mike - - Bristol
Just what I wanted to hear thanks.
