petrol tank reserve
Posted: Tue Jun 16, 2009 9:33 pm
by Andy Pickering
On they way to work this morning hit reserve so stopped within 1/2 mile and filled to the top..now to my suprise it only took 5 litres is this correct?..I know they hold 8 litres (standard tank by the way) but I wouldnt have thought reserve was 3 litres..brand new fast flow tap as well...normal or not ?...
Re: petrol tank reserve
Posted: Tue Jun 16, 2009 10:31 pm
by rakki
Don't know about the whole capacity of the tank but fast-flow fuel taps have much bigger reserve than original taps. I think that the 5 litres is normal with that.
Posted: Tue Jun 16, 2009 10:49 pm
by byron
yeah, I'd go with that.
all the new fast flow taps I have seen have a much longer reserve tube than stock.
Posted: Tue Jun 16, 2009 11:39 pm
by rog60
Posted: Tue Jun 16, 2009 11:52 pm
by Jet200
Rog60, we'd be lost if it weren't for the anoraks!
But I understand Lam46 concerns. The 1st time I fitted a fast flow I thought I still had about 20+ miles to go in tank when it went onto reserve. Thought fuel economy on this new set up was disastrous but then found out the good news when I went to fill up and it only took 5 ltrs.
Posted: Wed Jun 17, 2009 12:10 am
by goldeneye
funnily enough, went onto reserve this morning while dialling a carb in on "the mile"...... tescos petrol at one end , JET garage at the other......... fast flow tap, standard tank...... 6.75 litres, after putting the oil in. funnily enough(again)....... i went onto reserve, at the same place, different scooter, last week........... i had a quick glance up in the air in case "THEY" were looking for me............ or i might be just tight , and should buy some more petrol...........
Posted: Wed Jun 17, 2009 11:28 am
by bristolmod
most definately "THEY" looking at you
Try lining your helmet with tin foil- works a treat
