Page 1 of 2
Vespa px200E boggie bottom end
Posted: Mon Jun 15, 2015 1:52 pm
by boxofbits
Just rebuilt an engine px 200 e iris new seals bearings–new top end (all standard) as the engine had done alot of miles and needed a bit of tlc - Its really boggy at the bottom end—fine on tick over and once past ¼ throttle its off –but you have to rev it at the traffic lights else it stalls. I’ve tried a new float needle and a new plug and there no difference . I’ve checked no petrol in the gearbox oil- Adjusting the mixture screw does nothing either- Jets are 118 BE3 – 160 and pilot 55/160 – any ideas :oops: It did have 16 BE3 – 160 and pilot 50/160 in it when i got it- but it wouldn't tick over
Re: Vespa px200E boggie bottom end
Posted: Mon Jun 15, 2015 6:21 pm
by LI225Canada
Did you happen to replace the fuel line?
I had simulare symptoms on a friends P200 after I replaced his leaking fuel line with one 6" longer than the original.
Cut it back to the same length as the original and all was good.
Posted: Mon Jun 15, 2015 7:38 pm
by boxofbits
I will have a look, how long should it be?
Posted: Mon Jun 15, 2015 8:28 pm
by fastfrog
what sort of slide do you have on it? A 04?
I guess you have an autolube PX200E so you don't need a 118 main jet but a 116.
Posted: Mon Jun 15, 2015 8:42 pm
by boxofbits
Its a non auto lube it's its spanish 87 px 200 e iris I can't find a manual which says the standard jetting these model have
Posted: Mon Jun 15, 2015 8:55 pm
by boxofbits
It's a 04 slide
Posted: Mon Jun 15, 2015 10:10 pm
by fastfrog
and main jet is 118. My mistake.....
your mixture screw? how much did you wind it out?
Posted: Mon Jun 15, 2015 10:36 pm
by boxofbits
2 turns out is the mixture screw , also the idel is fulling wound in to make it tick over
Posted: Tue Jun 16, 2015 3:57 am
by LI225Canada
boxofbits wrote:I will have a look, how long should it be?
63cm.
Posted: Tue Jun 16, 2015 7:56 am
by mick1
Could be choke not fully shutting off......worth checking.
