Fork spring compressor tool
Posted: Sat Jun 13, 2015 7:22 am
by kevspeed
Hi all,can anybody reccomend a GOOD quality Lambretta fork spring compressor tool?,i have three (all from different suppliers),and they are CRAP
On all three the 'fork' part in the centre (the part that sits around the fixed ball on the end of the rod) bends all to easily,and thetwo sides splay out when under pressure
Back in the day,i did have a genuine Lambretta workshop item that did the job without issue,but unfortunately,i lent it out and never got it back
(a lesson learned),so is anybody out there re-manufacturing this tool with some degree of quality?
Re: Fork spring compressor tool
Posted: Sat Jun 13, 2015 7:44 am
by barnsleybilly
They all seem to be made out of monkey metal don't they.
Try using a ratchet strap instead, less chance of scratching your paint and does the trick.
Posted: Sat Jun 13, 2015 8:22 am
by Tractorman
Got to ask how you get the strap to hold on the spring rod?
Posted: Sat Jun 13, 2015 11:03 am
by barnsleybilly
Good point, I'm thinking of fitting the bottom buffer..........I'll get me coat
Posted: Sat Jun 13, 2015 11:57 am
by dave411
barnsleybilly wrote:Good point, I'm thinking of fitting the bottom buffer..........I'll get me coat
Posted: Sun Jun 14, 2015 11:12 am
by shocky
To help stop scratches someone posted a pic of plastic milk contaners cut and wrapped around the fork boot
Posted: Sun Jun 14, 2015 2:34 pm
by DigDug
Heat up the "jelly" tool until the business end is cherry red then dunk it in cold water - that should stiffen it up.
Also you don't need to be gorilla to compress the spring - just take it steady.
Posted: Mon Jun 15, 2015 12:34 pm
by dapper
shocky wrote:To help stop scratches someone posted a pic of plastic milk contaners cut and wrapped around the fork boot
'Twas I Steve. Didn't save the photos though
