Page 1 of 2
I got a bit carried away!!!
Posted: Thu Jun 11, 2015 6:27 pm
by DickieD
I got a bit carried away / distracted, the question is can this still be used? The damage is only where the flywheel bearing inner collar sits, the part the oilseal sits is undamaged. What do you think? Anyone done this and still used without problems?
Image20150611_180304 by Paul Davies, on Flickr
Image20150611_180251 by Paul Davies, on Flickr
Re: I got a bit carried away!!!
Posted: Thu Jun 11, 2015 7:09 pm
by Grumpy225
You could get it welded and re-ground but at this point it would be cheaper to buy a replacement.
Posted: Thu Jun 11, 2015 7:46 pm
by sean brady scooters
struth matey !!,you were for sure a bit heavy handed there lol...but no reason why it wouldnt still work as the seal surfaces are still intact and good .
Posted: Thu Jun 11, 2015 7:58 pm
by DickieD
Yes I know Sean, teach me to talk and work at the same time :lol: It should be tight on the undamaged parts and maybe a bit of locktight to make sure.
What's the consequence of it coming loose or spinning?
Posted: Thu Jun 11, 2015 9:45 pm
by wack 63
Buy a puller £20ish and never have to use a grinder again ;)
Posted: Thu Jun 11, 2015 10:53 pm
by B-Race Tuning
I found similar in a Malossi 210 before now and had been running fine for years apparently so don't see why not.
Posted: Fri Jun 12, 2015 2:28 pm
by DickieD
Cheers Simon I think I will give it a try and see how it goes.
Wack63 Iv'e always done it like this and never had a problem till now :shock: Have considered a puller but some are a waste of time where you get yours from?
Posted: Fri Jun 12, 2015 2:44 pm
by wack 63
Just Lambretta sell em or Sundar scooters on eBay.
Posted: Fri Jun 12, 2015 5:39 pm
by DickieD
Cheers I will have a look 8-)
Posted: Fri Jun 12, 2015 6:02 pm
by Shipleystevep
Someone posted a thread on here about that type of puller. I bought one in the strength of that and it's brilliant. Can't remember where from though :roll:
